Looking to sell my 1994 R33 Type M Skyline.
Bought the car just over 12 months ago completley stock bar a set of 17's and blown coilovers. I've added everything in the last 12 months, so all parts have very minimal use on them. Majority have less then 5000kms. I have almost all receipts for what ive bought and what work ive had done, and it's many thousands of dollars, more than the asking price.
I'll get the bad points out of the way first...
Both front fenders are munted. Previous owner rolled them REALLY badly, and the D/S has a couple of dents. Has a couple of carpark scratches and dents. Roof, bonnet and top of rear bumper have clear coat fade, but polish up ok. However does require respray to fix.
It's all cosmetic issues, which was all I had left to finish, once the mechanicals/driveline had been sorted. Get a pair of 25mm FRP front fenders and have the car blown over in the factory colour and it's done. Was quoted between $1000 - $1200 for a decent closed door spray in OEM black, you could spend more for a REALLY good job, or if you know someone who can do it you're golden
Now the good stuff...
Car is religiously maintained, using only the best gear (Nulon oil, redline gearbox and diff oil, ryco filters, Caltex 98 octane fuel) and also upgraded with the best parts money can buy. All work not done by myself has been performed by Shaun @ Boostworx, and he can also be contacted in regards to the car. Also in the last 12 months ive replaced timing belt, cam seals, water pump, tie rod ends, lower control arm and knuckle bushes, all the belts, and had air con fully serviced and regassed. Car also has a Viper 2 way paging remote alarm with remote start.
It's a perfect streeter, absolute weapon to drive, hit 3500 rpm and its all over the street, but super easy to commute in day to day traffic., it's just become impractical for me to keep, and have other projects on the go that I would rather finish.
Body
Type M Front bar/sideskirts/pods/wing, 8000K HID kit
Interior
Bride Digo-R seats in black/gradation on bride rails (Both Genuine with receipts)
Nardi Classic Steering wheel/Sparco Detachable hub kit/Yashio Factory shift knob
HKS Boost/oil temp/oil pressure gauges in Border Gauge pod, Yashio Factory Water temp Meter (To be installed)
Kenwood Head Unit/Splits
Engine / driveline
Rebuilt RB25 motor - CP Pistons/ARP Hardware/Greddy Metal Head Gasket - Full reciepts for engine build - over $10K worth.
APEXi Pod Filter/ Z32 AFM/Stainless inlet pipe (Have another intake pipe with no connection for emissions)
Trust TD06SL2-20G 10cm turbo/GReddy High-mount Stainless Manifold/Tial MV44 Wastegate/Braided oil and water lines
Plazmaman FMIC And piping
1 piece dump/front/APEXi 3 inch exhaust (Not too loud, good on the street)
Nismo fuel pump/Nismo 550cc injectors
APEXi Power FC ECU tuned by Shaun @ Boostworx - 270rwkw @ 19psi with dyno sheets. More in it with a decat pipe and some cams.
Nismo GMAX twin plate clutch/Braided clutch line/urethane gearbox mount/Nismo pivot ball
Nismo 2 way LSD, alloy diff mounts
Alloy radiator/Silicone Hoses/Nismo Thermostat/N1 water pump
HKS oil cooler kit with filter relocation
Optima Dry Cell Battery
Wheel and Tyres
Enkei RPF1 wheels in silver, 18x9.5 -5 and 18x10.5 +10
215/40 and 235/40 Tyres
Suspension setup - FRONT
Cusco Comp S coilovers – 10kg
Cusco Adj. Upper arms
Cusco Adj. tension Rods
Nismo Tower Bar w/master cyl. brace
Suspesion setup - REAR
Cusco Comp S Coilovers – 8kg
Cusco Rear upper arms with eccentric lockouts
Cusco Cradle collars
HICAS lock bar
Im asking $13,000 negotiable upon inspection, car has current rego with just less than 3 months left.
May consider trade for HSV/V8 Commodore as a daily
Contact Ben on 0439 888 043, or [email protected]
Edited by R31 drift pig
What would be your best price you can do on it? Im interested and im from Melb so i wont need the reg or rwc and ill be paying cash, so if you can give me a really good price i will come and take it off your hands.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
