Happy Laps - Queensland Raceway 22-03-14
you said before we went on track that you didn't want to line anyone up haha you just wanted to do the happy laps thing... :)
.... :/ that dosent sound like something id say
I remember saying I had no intention of flogging it's guts out
havent used a gopro before but the quality looks good, so suspected it was a gopro... ;)
Yeah, thats after I cut it back to 720p so it wasn't too big. They are a little on the pricey side if you just want one to film round a track but well worth the money if you want to also film more extreme stuff.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
