Queensland Raceway regularly hosts Friday Night Drift Practice which provides top drivers a chance to test new setups and equipment but more so an opportunity for new-comers and social drivers to see how their car performs - and most importantly how their driving stacks up.
Friday Night Drift Practice is a great social night as we run 2 drift circuits simultaneously as well as the skid pan in the front car park. The night is STRICTLY limited to 100 drivers so entry is on a first-in, best dressed basis.
All you need is:
  • A rear wheel drive car
  • Neck to ankle clothing
  • An AS/NZS 1698 Standards helmet
  • Closed in footwear
  • QR Clubman licence
  • Mates to help change wheels and tyres
  • Spare tyres for the drive home
Practice Dates for 2014:
Friday 14th February 2014
Friday 28th February 2014
Friday 14th March 2014
Friday 28th March 2014
Friday 18th April 2014
Friday 25th April 2014
Friday 16th May 2014
Friday 6th June 2014
Friday 13th June 2014
Times:
Gates open for Drivers and Spectators at 4:30pm and Drift sessions commence at 6:00pm.
Prices
Drift & Skid Pan $80.00pp Skid Pan ONLY $50.00pp Gate Entry $10.00pp
Passengers no additional cost. Must be 16 years & over (Photo ID must be shown).
For more information please phone the office on : 1800 RACERS
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
