HKS TYPE S OIL COOLER KIT & APEXI POWER FC + HC
HKS Oil cooler kits help cools the engine oil better. On the track, oil temperatures can reach in excess of 130 degrees Celsius. This reduces the viscosity of the engine oil and may lead to engine damaging results, due to the lack of lubrication though the engine. With cooler engine temperatures, the engine will perform better and be more reliable.
This is the base model Oil Cooler Kit that comes with an adaptor that fits in between the oil filter. The lines connecting to the oil cooler will then attach to the adaptor. Comes with all necessary hardware for a straight bolt on fit. Most kits come with a stainless steel shroud over the oil cooler to better help direct air into it.
1x HKS TYPE-S OIL COOLER KIT FOR R33 GTS-T .......... $950o.n.o
1x APEXI POWERFC + HAND CONTROLLER FOR R33 GTS-T ............ $SOLD$
all new, located in sydney, can ship anywhere
need to sell urgently
https://www.sau.com.au/forums/topic/43890-hks-oil-cooler-pfc-w-hc/
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
