Wtb R33 Gtst Parts. Bonnet/headlights/front Bar/exhaust/speed Sensor/abs Relay/lighter/rubber Gear Boot
Hey,
Currently trying to source the following for my Series 1 R33 GTST.
- Bonnet (Preferably black or the navy blue colour)
- Headlights
- Front bar (Preferably black or the navy blue colour)
- Exhaust (Doesn't have to be complete, could be catback or just a front/dump pipe as I can mix and match)
- Speed sensor as my speedo stopped working
- Abs relay
- Cigarette Lighter unit as mine is empty so not sure what wiring is needed etc too
- Rubber shifter boot as mine is split underneath my shifter surround and I can smell gearbox fluid....... :(
- Front mount with piping
- R33 GTR front seats
Can text me on 0468 330 099 as its easier but I can check pms too... Willing to pick up anywhere In Sydney or within an hour or two from Sydney.
Edited by deva0o
I've got a newly sprayed black bonnet and jasma stainless cat back exhaust I could do both for $320 but I'm in Melb :( . Just on the off chance you were road tripping...
Thanks for that. Yeah unfortunately just looking locally.
  • 4 weeks later...
    • I downloaded the apps (for windows) and Consult 1 doesn't have this function on it for the Consult 1 plug which I'm pretty sure all Skylines have. You would think someone would have a workaround after 30 years for all Skylines which have ABS.
    • Also, I don't know the actual ABS system on the skylines, but a sneaky thing could be a piece of electronic equipment that makes the ABS think you're moving, and then same piece can send a signal for a locked up tyre... Activate ABS without slamming brakes...
    • The team at OBD2 Australia are pretty good, shoot them an email and ask them. I've dealt with them before for work stuff. I'd be shocked if it didn't work, so long as Consult can activate the ABS. But you might need to use KLine for it which would be the stopper, as I don't think that piece does KLine comms.
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
