I have some parts left over from my build that could use a good home.
Contact: text 0433046838 or pm
-NZKW oil cooler with filter relocation and braided hoses brand new unused, was going to track my car but not anymore so unneeded. Paid $400 yours for $200
-rb awd sump with front diff $200
-rb20det out of gts4 r32 suit rebuild $200
-rb20det injectors / rail with stock fpr $120
-rb20det cams $25
-rb20det cam gears $20
-rb20det afm $50
-Rb25det injectors / rail with stock fpr. Came off 125,000km stagea $200
-s2 r33 rb25det manual ecu $150
- mines chipped rb25det ecu (fmic, 3", pod, 1bar) $200
-s2 rb25det afm off 125,000km stagea $80
-s2 rb25det cams $25
Cheers :)
https://www.sau.com.au/forums/topic/439411-rb20-rb25det-std-parts-sale/
  • 3 weeks later...
