Hi,
Clearing out the garage...
I have a complete set of 'used' Advan A050. Originally purchased new from Gordon Levin for around $500ea. These would be ideal for someone with an EVO or some sort of AWD setup. Cheap tyres which are a definite step up from using regular street tyres. Fantastic for someone wanting to get into circuit as well.
Product Description:
In good condition. No flat spots, and have been stored properly in the garage.
There is approx 2-3mm of tread left which would easily see 2-3 trackdays depending on how you drive.
Medium Compound
04/11 Build date
Price:
$675 Negotiable
South West Sydney
Shipping info:
Local pick up OR happy to ship at buyers expense. East coast metro should be approx $75
Contact:
0403337740 or PM
  • 3 weeks later...
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
