R33 Rough Starting Up
By MissMintyR33 · Posted
Hopefully this video loads, this was a month ago, it isn't as bad now (with the back fire) it's more of a hesitation at certain RPMs Snapchat-1404613580.mp4 -
I had splitfires before the rebuild, however I was looking at an issue spark related and put another lot in (savage performance) but it ended up being my piggy back ecu + the coil module, so I still have the splitfires laying around -
Gap your plugs down to 0.8mm What coil packs are in it? I assume they weren't replaced when the engine was rebuilt.
1.1 Denso Iridium It's random really, I can go to a high rpm okay one time and then it'll lag/hesitate .. it's hard to explain what it does. It's not a backfire, I think I'm gonna have to try and video it when I fix my steering issue. sometimes it'll do it taking off from lights at a lower RPM -
It's a direct aftermarket from NSW, my factory Nissan one shit the bed. Are aftermarket no good for them? Was splitfires removed to see if they were causing a seperate issue and had some savage performance from NZ ones I put in
