2001 Nissan Skyline 4 droors, 92,212km, V6 3.0L, 5 Speed Automatic Transmission with Manual Mode.
Well maintained at Nissan Unley premium luxury sport sedan optioned out with Premium Package including leather/suede combination interior.
- 17" Nissan OEM Alloy Wheels with New Pirelli P7 Tyres
- New DBA Cross Drilled/Slotted Brake Rotors (HD Gold 4000 XS Series)
- Nismo High-Perfomance Brake Pads
- Fujitsubo Japanese Stainless Steel Legalis R Exhaust System
- Full stereo upgrade with ALPINE MP3 music system (front USB input)
- ALPINE Type-S and Type D Two way 6.5" Coaxial Component Speakers, Tweeters
- Full Sound Deadening Treatment
- All Power Windows
- HID Head Lamps Auto Mode
- Fog Lamps
- Driver/Passenger Electric Seats
- Electric Mirrors Auto Folding
- Auto Climate Control
- Centre locking
- Anti-Lock braking System
- Power steering
Excellent condition, 1 owner, all inspections welcome, no swaps thanks
Location Adelaide
$11,999
Call or text me 0477 224 749
Cheers
  • 1 month later...
  • 1 month later...
c'mon guys :yes: only one 3L sedan in SA
- New DBA Brake Rotors HD Gold 4000 XS Series
- Fujitsubo Japanese Stainless Steel LegalisR Exhaust System
- Full stereo upgrade with Alpine MP3 music system front USB
- Alpine Type-S and Type D Two way 6.5" Coaxial Component Speakers, Tweeters
- All Power Windows
- Fog Lamps
- Auto Dual Climate Control
- Centre locking
- Power steering
Serious buyers only, no test pilots.
  • 3 weeks later...
  • 2 months later...
Well maintained premium luxury sport sedan -
- Full stereo upgrade with Alpine stereo head unit
- Alpine Type-S and Type D Two way 6.5" Coaxial Component Speakers/Tweeters
- All Power Windows tinted with Lumar film
- Fog Lamps
- Centre locking
- Power steering
  • 1 month later...
$10,500 :yes:
new photos of mods & services done
* Stainless Steel Exhaust System Fujitsubo Legalis R
* New DBA Brake Rotors HD Gold 4000 XS Series
* New Wheel Hubs & Bearing
* Fuel filter replaced
* Oil change and fluids done in gear box, power steering, brakes and coolant
** Only OEM Nissan spare parts and fluids have been used. Always run on BP Ultimate 98.
Any inspections welcome. Feel free to contact me with any queries on 047722474 nine
  • 1 month later...
The car has travelled genuine 92,212 kms :yes:below my original registration document - Export Certificate and the translation -
JapRegistrationCertificate_zps01069165.j
In Japan, cars have to be registered every two years. Part of the inspection is an odometer check and the odometer reading is recorded together with the owner details. This watermarked document states the odometer reading of your vehicle at the time of the last two registrations before the export date.
  • 3 weeks later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
