i have scanned my car code 21: ignition signal circuit (0 starts ago)
replaced coilpacks and nothing changed just engine icon there and my car misfires like hard sounds like a tractor for a good 5 minutes then it goes away and its fine but engine icon is still on dash anyone help?
https://www.sau.com.au/forums/topic/441789-ignition-circuit/
