HKS EIDS
HKS idle Stabilizer. Helps solve the stalling problem caused by most ATMO BOVs.
Comes with Computer, Loom and Instructions.
PriceSOLD (UAS have one for $280)
Buyer buys postage from SA. Prefer Direct Deposit, COD maybe.
in excellent cond.
Thanks, Dean
https://www.sau.com.au/forums/topic/44218-fs-unichip-ebc-and-hks-eids/
calemb : If uve ever installed a car stereo, then u can easily install this. U need to tap into only 8 wires. Took me 10 mins to install.
Yes it works on autos
Yes it works with other EBCs however it works as good if not better then the brand name ones. Buy this, and sell the brand name one if u r happy with it, and u saved urself a shitload. :)
Pics Finally,
Sorry about the crapness of them, my camera isnt workin so i had to use my el crappo one.
Pics are Unichip and Boost controller Modules
Wiring loom pic of boost controller and Unichip (Still attached to my car)
Thanks
Dean
read this link... it tells you why you should install a unichip intto your car.
http://www.airpowersystems.com.au/unichip/unichip.htm
The Unichip not only enhances power and torque across all throttle positions throughout the entire rev range, but significantly enhances throttle response, driveability, fuel economy and outright acceleration.
James.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
