Hi,
Sorry if this has already been answered, I have had a look around but couldn't see a definite.
Will this style of intercooler fit a S1 Stagea ?
Listing:
http://www.ebay.com.au/itm/KLS-INTERCOOLER-PIPING-FULL-KIT-NISSAN-SKYLINE-R32-R33-r34-RB25-RB20-turbo/191139298348?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222003%26algo%3DSIC.FIT%26ao%3D1%26asc%3D20140106155344%26meid%3D6396917397384694418%26pid%3D100005%26prg%3D20140106155344%26rk%3D2%26rkt%3D6%26sd%3D230869357899&rt=nc
Direct link to image:
http://i.ebayimg.com/00/s/MzYwWDM2MA==/z/eEAAAOxy0x1TT2D6/$_12.JPG
Looking in the engine bay it looks like drivers side would be a tough fit.
Thanks
https://www.sau.com.au/forums/topic/442213-intercooler/
^^this.. also, this is next on my shopping list: http://m.ebay.com.au/itm/371047755695?nav=SEARCH
A quick search around will reveal all. People have also used xr6 turbo intercoolers with success. The one you have listed probably will fit with a hole under the battery tray and a small bit of massaging. Alternatively, an r34 smic is a nice stealthy upgrade.
Edited by c34Florry
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7264609
I used one of these in my wagon:
http://www.frozenboost.com/product_info.php?cPath=207&products_id=208&osCsid=eeaa0b07c62725c35347ccedff7d7964
I was looking for a vertical flow unit for ages. I knew what I wanted & found it here, a complete guide:
http://www.skylinesaustralia.com/forums/topic/424157-r34-gtt-fmic-with-no-bodywork-cutting/
This is a much better option. Lag is an important consideration before buying. The one I picked is just under twice as big in capacity as the stock one with 2.5'' piping, & I gained 400rpm lag (2,200 rpm - 2,600rpm). Like the cooling pro unit it has 2.5'' inlet/outlet. Understanding why a vertical flow intercooler is better than a horizontal flow requires research, as this would be a very long post to explain! It might have a smaller surface area, BUT, it is 3.5'' thick. It was a no hassle install with NO cutting of the front reinforcement bar or bumper. Very neat & tidy, & even with slimline number plates & black colour, nobody even knows it there :ph34r:!!
My next intercooler will be even better, air to water!
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7267655
I used a JustJap 'Cooling Pro' return flow unit. Contrary to what most people say about non-Japanese stuff, this kit is well made and includes the correct length hot and cold side piping. The only issue I had with mine was fabricating some nicer alloy brackets, as the steel ones supplied were pretty average looking.
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7268360
^^^interesting. I never knew these existed until now.. doing some reading and they sound awesome! Do you need to buy a specific piping kit for these or did you make one up yourself?
Nope, just bought a piping kit from ebay out of china. Like this:
http://www.ebay.com.au/itm/2-5-INCH-ALUMINUM-TURBO-INTERCOOLER-PIPING-KIT-PIPES-CLAMP-COUPLER-UNIVERSAL-/260882361775?pt=AU_Car_Parts_Accessories&hash=item3cbdccedaf
I specified black hoses when I ordered it.
When I ordered the intercooler, I ordered the 60 degree (#1), the 90 degree (#3) & the 45 degree (#7 in the pics of the guide). As it turns out, the the ones I ordered with the intercooler were 5 layered hose & the china kitted hose was only 3. If I did it again, I'd get all the hoses from the U.S. with the intercooler.
The piping kit wasn't barbed on the ends of the pipes, but I didn't see an issue with this as scotchbriting the pipe & painting it black gave it plenty of grip, PLUS I cut my pipe so there was PLENTY inside the hose when fully assembled. Once it was all finished, the piping hardly moved at all, so, no chance of blowing a hose off!!
You'll have plenty of pipe & hose left for other projects down the line too!
  • Like 1
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7268522
I just noticed you posted a link to a most helpful tutorial lol. went to frozenboost.com and all the parts youll need comes in au$100 cheaper inc. delivery (us$477)than the cooling pro (au$599) AND its more efficient.. AND there's no cutting of anything required.. lovely.. do want
Edited by c34Florry
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7268562
The intercoolers most companies market (horizontal flow) are fairly useless for the applications most people use them for. The might be ok IF you are running in excess of 30psi & 150 degrees C.
Check this link out, its FULL of equations. This link should be stickied for anyone wanting to create a good combo!
http://www.gnttype.org/techarea/turbo/turboflow.html
https://www.sau.com.au/forums/topic/442213-intercooler/#findComment-7270457
    • Sounds more like what Brad said, that it's mainly transfer. What pad bed in procedure did you use, and did you replace/machine the rotors, or just swap pads?
    • The stutter is almost entirely in the pedal. I don't feel the brakes release and reapply as you would with ABS engaging but the pedal feels that way, without the brakes releasing. It only lasts for less than a second and the pedal is fine again. It's hard to explain, sorry.  I'll get under this weekend and just double check everything is tight. Fluid is at max where I left it.
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
