hey all,
I have an rb20 for sale
its complete minus the following:
- starter
- alternator
- a/c compressor
- power steering pump
- coilpacks
- all exhaust side
- turbo lines
history of engine:
i bought a complete stock 1993 r32 gtst that could not be compiled. i used it as a parts car to put turbo running gear on my na r32 and to do an na + t conversion
car was running fine before i stripped it. engine has done 100000kms.
im in wollongong nsw and engine is on a pallet
will consider separating if there is enough interest
$500
Pics
https://www.dropbox.com/sh/4y0ax8a4bghacun/AADyaD7XgzZZiT6AE7_2pbuba
Note: top of inlet manifold and throttle body are not in pics but are now back on engine
Engine was also mated to an auto which is also available for sale - $200
Jase
Edited by gts25
https://www.sau.com.au/forums/topic/443170-rb20det-engine-nsw/
  • 4 weeks later...
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
