Hi,
Selling another '03 V35. This was swapped for my supercharged V35 plus cash last week.
Immaculate condition. No dents or scratches anywhere, headlights just need a polish. 2nd owner in Aus.
Odomoter: 76,xxx
Condition: Good, drives like a brand new car.
Only modification are a GROM (Bluetooth handsfree/iPod/Aux/Micro USB), plasti-dipped front grill and wheels, and reversing camera.
Handful of 350GT/premium features including auto-retracting mirrors, down tilting mirrors on reverse, CD player, Bose sound system, leather interior etc, dual climate control etc.
$16,000 ONO
SMS ONLY: 04 333 70 258
Thanks.
Edited by Magic
https://www.sau.com.au/forums/topic/443676-fs-v35-skyline-350gt-coupe-wa/
If you still have the car in like 4 years I will 100% buy that if I have the money
I will 100% buy whatever the latest McLaren is in 4 years if I have the money.
In more serious news, price drop down to $15,000.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
