Both the tail and headlights you are talking about are custom jobs, they arnt off the shelf items...
There is a thread on here by a well know dude who does projector conversions, he doesnt do skyline headlights but did a good tutorial in the cosmetics section...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
