Hi All
I have a an GTR and Silvia that are in need of some compliance. My mechanic has been chasing up what the requirements are from various engineers (some say that even tyres need to be changed to DOT marked, others say new seat belts...which wasnt what I thought the 15 YO scheme was about) but he has gone on holidays so I am left to sort out what can be done.
Anyway I was hoping we could get some ideas of the what is actually required to be changed and whats engineers you use in Victoria and other states.
J-Spec quoted $1400 per car which is ok I suppose (flat rate for all 15ers), but seeing as the whole deal with the 15 YO rule is that anyone can do the compliance and then just take it for sign off by an engineer, I was hoping to just do all the work myself and then get it signed off. If the savings arent substantial then I suppose they will be off to UPI or J-Spec.
Any ideas would be appreciated.
Seat belts, mirrors, Intrusion bars, sunvisors, child restraints
helps to have DOT approved tyres on when you go through the roadworthy too
btw why have you started an import business if you don't even know the basic requirements to register a 15 year import?
Hi All
you can do the work yourself and deliver the car to an engineer, but some of the items are not that simple, belts are not required if there in good nick, but must be retractable in the rear, which silvia usually doesnt have, tyres are ok if they are roadworthy.
but intrusion bars are a pain, if u attempt them, make sure you speak to your engineer as they all have different requirements for dimensions and the way they are fixed, fuel filler restrictor is also a pain if you dont have the correct tool, r32 filler necks are a pain.
we charge $1300 for r32 and $1500 for silvia(silvia requires rear belts)
Dean
I did mine.
Piece of piss if you get the intrusion bars done properly and the fuel restrictor done.
Someone had attempted to do the bars in my car without talking to an engineer so I had to cut bits out INSIDE the doors to prevent them rubbing and knocking on the glass, then get the engineer to weld around the cuts. Was a pain in the arse but not overly difficult because I had access to small dental drills which cut steel easily with the right disc and can get in to very tight spots... But you'd want to get it right first time because you wont have the luxury of being able to cut bits out once theyre welded into the doors.
The rest of it is easy, just time consuming, you need to make it all look neat and tidy and like any work that was done was done properly. I got my car through Regency first try (bar the steering wheel because they wouldnt accept the Isotta as the paperwork allowing Isottas wasnt due for another couple of weeks, but they let me drive to a wreckers and buy another standard wheel and come straight back)
Easy
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
