For sale is my 1991 Nissan A31 Cefiro. Series 2 RB25DET conversion, Serviced every 5000km's with Penrite 10Tenths Fully synthetic 15w50 Racing Oil, 3 inch full turbo back exhaust, Hi-flow cat, Manual RB20 gearbox, 5 stud conversion front and rear, R34 GT-T front brakes and R32 rear brakes, DBA slotted rotors front and rear, Tein coilovers, Whiteline swaybars front and rear, alloy radiator, Walbro fuel pump, Yellow Jacket coilpacks (fitted may 2014), Remote oil filter and oil cooler, battery has been replaced to a 600cca also.
Interior: Dark interior, Manual dash cluster, manual centre console plastics, S15 drivers seat, full passenger capacity rollcage (modplated), Nardi Classic steering wheel, dash mat, cold air con, Cefiro floor mats, Boot interior complete.
Exterior: Autech Front Lip, Series 3 Chrome Grill, B&N side skirts, Autech copy rear bar, Dark slimline weathershields, Blitz Type 03 2 piece 18x9 +22 rims all round, Federal 595 ss tyres all round done approx 5000k's, Custom flared wheel arches, DMAX Roof spoiler, Dark series 3 tailights (currently has dark and red as drivers side dark has a crack), has been resprayed in Ford Ego Gunmetal Grey, CEF111 personalised number plates (can be sold with/without plates)
All major modifications are mod plated and were done by previous owner as this cefiro was originally a non-turbo, auto, 4 stud. Motor has done about 150000 k's. This is one of the cleanest Cefiro's I have seen inside and out, very well looked after and maintained.
Since owning this vehice I have done the usual services (oil, oil filter, spark plugs, air filter, fuel filter) fitted the rear DBA slotted rotors as well as the rear Bendix brake pads and fitted the rims with Federal 595ss (done approx 5000k). I have also purchased high flow cat, all new inlet to rocker cover, rocker cover to rocker cover and rocker cover to exhaust hoses from nissan as the old ones were rock hard. April this year I have replaced all inlet gaskets as well as getting the fuel rail cleaned, injectors fitted with new pintle caps as well as new orings to the inlet where the injectors sit, new top radiator hose with fresh coolant as well as new thermostat and rocker cover gaskets. May this year have just fitted new Yellow Jacket coil packs ($410) as my old stock ones were buggered.
Selling my car due to our family going back to one so mine is on the firing line. Car has always been reliable (my family car) so I hope the next owner will love it as much as I do.
Can sell with roadworthy or you can get your own whichever works/easier. Cash talks, not interested in swaps of any kind. I travel to caboolture once a fortnight for anyone who doesn't want to travel to Gympie to view the car. $11500 ono. Rego due 12/10/2014.
Thanks,
Kailea
0407939624
[email protected]
post-112267-0-54563100-1403233010_thumb.jpgpost-112267-0-84357000-1403232942_thumb.jpg
post-112267-0-72923100-1403233026_thumb.jpgpost-112267-0-51923500-1403233040_thumb.jpgpost-112267-0-06146900-1403233056_thumb.jpgpost-112267-0-25959100-1403233069_thumb.jpgpost-112267-0-09344900-1403233085_thumb.jpgpost-112267-0-60151100-1403233096_thumb.jpgpost-112267-0-56071700-1403233105_thumb.jpgpost-112267-0-49237300-1403233116_thumb.jpgpost-112267-0-40727000-1403233128_thumb.jpg
https://www.sau.com.au/forums/topic/444671-1991-a31-cefiro-series-2-rb25det/
  • 1 month later...
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
