Hey guys,
Just clearing my stuff out, planned on using them but never did. Prices are slightly negotiable.
Item 1: Pair of Rays 17x9 rims with 265 Bridgestone RE01 tyres, unknown offset, has a bit of dish
Condition: Needs a clean but in very good condition. Rattle canned black.
Price: $200 ono
Item 2: 15mm Neotech hubcentric Spacers, suits Nissan hub.
Condition: used but in good condition
Price: $80 ono
Item 3: Replica Nardi 330mm deep dish steering wheel
Condition: Near brand new, used for a week then upgraded to genuine 350mm
Price: $80 ono
Item 4: R33 s2 silver boot and s1 silver wing.
Condition: Very good. Boot has no lock
Price: $50 ono
Pics to come.
Located in SW Syd, prefer pick up but can ship steering wheel and spacers.
Cheers,
Mike
Edited by macaroni646
Hey mate how many wheel spacers is it? 1?2?4? May also need the steering wheel to pass rego as mines torn. Are you available this coming weekend ?
    • Thanks, I'll shim that plug and hopefully it fixes it.  Yes still factory turbo for now, still have the misfire it's not as bad but still noticeable
    • I had someone check the CU, they said it was fine but it could be buggered  I was only running around 7-10 PSI on the dual stage controller, but my boost gauge is shit house and needs replacing so I'm not getting a true reading.  Then I ran from wastegate pressure as per Turbosmart but still have the same sort of issue
    • Yeah this is a thing. I've had mine setup like this for a few years now, works fine. If I dredge my memory bank, I think I had to do this after I removed my factory dash.  So you've tried it on gate pressure, I'm assuming this is the factory turbo? Did you still have misfire issues with that setup?
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
