hey all just bought my self a GTR 32 , after market exaust , front mount and computer , im thinkin of hittin the quater to see wat she runs , just curoious on any ideas wat she will run on stoock boost ? also wats the max boost u can run on a one these if any one knows that will be great ??. thanks all cya
https://www.sau.com.au/forums/topic/44526-r32-gtr/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
