My dyno printout - Sat 26th (Cyrus put yours in please)
woa.. thats all over the shop. Sorry to say - almost n/a figures :) very linear there?
sir31 got 88rwkw from ye olde SOHC RB30E .. http://forum.r31skylineclub.com/index.php?...10913.0;id=1327 same dyno a few weeks ago..
that linkonly work's if u a reg member to the site..........try this one..........
http://www.boostcruising.com/members/showi....php?dbpic=1752
will i sick of the n/a i brought a RB20DET on the weekend
  • Replies 41
the gain cyrus achieved with the exhaust just proves how much a decent exhaust can give your car.
neil dont worry man, theres always a faster car :D in stock form i pulled 168kw on that dyno :)
yer i couldnt make it, woulda liked to go but i was stuck under a 180sx all weekend
Anyway guys....here is my chart from Saturday at AllStar with the Zed Club.
See if you can spot where the A/F ratio was lean enough to make the car ping, retard timing and bugger up the rest of my run :)
Anyway the power figures are low...apparently this can be confirmed by most people that use the Allstar dyno....but as everyone knows they're a tuning tool, not just for horsepower queens :D I did manage 97Kw on the first run...but as mentioned before, it started to retard quite badly.
I've adjusted my AFRs so the Mercury Motorsport weekend should be better for comparison reasons.
I was told not a bad effort considering I've still got the N/A exhaust fitted...hmmm back-pressure!
GEDAY MATE
YOUR A/RS ARE VERY LEAN MATE.
I WOULD TAKE CARE UNTIL YOU SORT THEM
I HAVE SEEN MELTED PISTONS IN RB25s FROM A/Rs LIKE THAT
BY LOOKING AT THE CHART - YOU ARE DEFINITELY GETTING KNOCK RETARD .
REGARDS
BILLY
GEDAY MATE
REGARDS
BILLY
So ya like allcaps eh Billy?
Anyway did a bit of searching today, managed to find a way to finally connect the igniton harness up without killing the coils....about time the timing had something more technical done to it as opposed to the old chesnut of turning the CAS :P
Also found a place that stocks a wideband O2 sensor that connects up to the e-manage for data logging.....will also help things a bit.
Or maybe I'll just piss the engine off and throw a nice RB26 in :P
Yep hungry6…I’ve been thinking about that lonely engine and how it would be much happier sitting in my engine bay :D
Fro - A GTR engine would improve lots of things…..except your sisters patience with me!
So on that dyno he got an extra 15rwkw just with adding a cat back exhaust?
Yeap 101rwkw before with stock exhaust 116rwkw with Beau's HKS Super Dragger Cat Back zaust. :D
I'm back, went to morton island (sp?) got home last night, I have both printouts and will scan and post tomorrow when I am at work, catching up on some sleep after doing more exercise than I did in the past 3 years in 3 days, I'm feeling quiet :throwup: atm, so yeah some of those Zed cars where just SEX ON WHEELS! OMG The first guy to run, pulled 212rwkw, and that was on his "low" boost setting, he said he was going to do some tweaking and hope for 230rwkw!!! Awesome blokes, awesome cars, Thanks for the invite too!
Abo bob, nah the auto can work with the harness it's the fact that the constant load on the coils makes them fry...just like the RX-8 coils.
If the holding voltage can be stopped..and only the peak firing signal sent..then the coils work fine. For some reason the e-manage sends *hypothetically* 2V continuous...then a 5V peak on firing signal...then back to 2V etc etc...it's this 2V holding voltage that keeps the coils energized and makes them cook after a little bit of time....if they went back down to 0V between firing then there would be no problem.
Just going to hook up a circuit in series with the signal wires to only let through the peak voltage...I'll let you know how it goes. And I only just sold the harness a month or so back :D
that bit dan...not the rb26 bit....
will the o2 sensor show extra data an your laptop tp help u tune it? and the other thing about the coils, if youd done that in the first place would you have needed new coils?
    • Hello Liam - HA - somewhere in flies - possibly I have an update, but I have been so busy, projects have taken a back seat to getting business back on track.  I will let you know the outcome, but I think I am going to go for the 8HP,  CHEERS.  ELVIS
    • Thanks Joshuaho96, yes - as someone else also suggested, the 8HP seems the 'smart choice' - HA - and ZERO to do with cost, but I am sure 8 speeds will be better than 6 speeds - HA - maybe.  I will purchase a new 8HP,  Thanks.  ELVIS.
    • Nobody said anything about getting a "...cheap Falcon box..."- it was JUST a question about a specific transmission.  And YOU may have a problem with not enough $ - HA - I do NOT - so please keep your comments like you are some financial guru to yourself.  BUT - much appreciated re the cost of a new 8HP and I twill probably be the way I go.  Thanks.  ELVIS.
    • Most people I know in the BMW world are swapping 6HPs for 8HPs. The 6HP has a big issue with one of the clutch drum bushings wearing out shockingly early which leads to them going into limp mode going into 5th/6th gear as the oil pressure loss from the worn bushing causes clutch slip. Even with the adaptations in shifting the TCU can't bump line pressure enough to keep the clutches from slipping and burning. I've personally looked at a 335d with 6HP28 with one owner and ~90k miles on it and the transmission adaptations were way out of spec and even though it nominally drove ok I'm confident it would have needed a full rebuild sooner than later. Other than that they're fine, but the 8HP doesn't really have weird issues like this to my knowledge and they're in everything these days so pulling them out of crashed cars isn't too hard.
    • There is an ABS pump and a few solenoids. You could trigger the front/rear solenoids with a pressure bleeder attached with a Consult 2.
