Hello gang,
so for a while now my car has been doing some weird and annoying shit, it happens mostly when i back off the accelerator - it's like the throttle doesn't back off completely, it will still cruise almost on it's own before finally backing off. same when i change gears because the revs don't drop off properly sometimes it sounds like when you get back on the revs to early when changing gear
also at idle sometimes, not that often but sometimes it will just climb in revs up to like 1200 / 1400 for a while and then drop off back to 800/900
my first thought was IAV but i'm pretty sure there are a bunch of things that can f**k with idle,
has anyone has this problem in particular when backing off?
thanks
https://www.sau.com.au/forums/topic/447242-r34-rb25det-idle-backing-off-issue/
have you got an aftermarket bov? it sounds like a vac leak somewhere
if your iac valve was shagged it wouldnt idle and just hunt flat out. once you back off the car will just die on the spot.
yeah i have an aftermarket bov but it has never been a problem until recently
sometimes when it's playing games with me i can just rev the tits out of it in neutral to like redline and it will make it go away for a while, i do that when it's being really annoying
:unsure:
Suspect a vac leak or BOV issue...
it is an atmo bov, it was like that when i bought the car and all the inlet piping is custom from the throttle body to the intercooler so swapping back to stock is kind of out of the question
regardless i've never had any of the problems others have with atmo bov's and stalling
i think i will change all my vacuum hoses, i'm over the tacky blue ones the car came with anyway
in saying that maybe i will investigate plumbing it back, just to be on the safe side
Its not going to hurt! My GTT hated the atmo one when i had the stealth GFB thing on it, i had to rotate it until it was basically plumb back to get rid of the issue due to the reversion etc!
  • Like 1
  • 1 month later...
so an update, i finally go around to changing all of the vacuum hoses which was fine. changed out shitty looking blue silicon ones puts on by a previous owner at some point for black rubber ones
long story short, hasn't made any difference at all
in the past couple of weeks once it gets to the temperature where it all starts to back off and idle shit the TCS / Slip lights have been coming on sometimes and even when i am backing off down a hill the engine light comes on sometimes, when i get back on the power the engine light will turn off again. to be clear the coil packs are fine they are aftermarket items i put in myself a couple of years ago after i bought the car, it runs fine under power there is no missing. those lights can come on sometimes when i'm not even moving at a set of lights
could it be something like the AFM?
Edited by mystery_kid
it runs really nice when it's cold, nicer now that i've changed all the vac hoses. when i finished fixing it yesterday i let it warm right up and then i took it for drive around giving it a good squirt and it was fine
i drive to work this morning which is only a 10 - 15 minute drive and like clockwork at around 65º~ it just starts being a flamin mongrel when i back off, idling high etc
    • @GTSBoy yeah i know it was not the "great" idea but it is and option...but i think i will stay on no BoV rather then trying to make it work with "half" this and that. But that GReddy FV2 is cool...i like that you can make it like stock if you want (and have/make the custom pipes) For other thanks! it was alot of information. But for the sound...a dont rly "like" both of them...specialy if they are loud...but if i "must" choose i would rather have little whooosh rather than sutututu with no BoV....BUT that is what is i gonna get. So for the all info i gather. In my case:  No BoV is not that bad cuz it is stock...and iam used to put N/clutch right after rpms are around 1000 so it should be ok...just need to avoid "big" drops. But i do not have the engine in the car so i do not really know how "bad" or good it is. But as i had that little test drive it looked ok. The atmo BoV should be worse car would dump to much fuel specialy between the shifts...so without proper tune/ECU i dont want that. BUT with that...car should drive ok with no problems right? (i do like there is less piping wih this solution) 🙂
    • Usually an RB20 won't stay in closed loop idle anyway. The O2 sensor gets too cold, stops swinging.
    • They aren't, but it depends on what interests you about an R32-R34. If it's the front engine I6 turbo that tunes well with a manual transmission an E92 335i 6MT is so incredibly cheap. You can get a super clean one for 20-25k USD tops. Put an LSD in it, tune it, have fun with it. If it's the general idea of AWD + turbo and a manual transmission the 996 Turbo is absolutely much more expensive, it's less practical but it's also basically a complete track-ready car from the factory. At least the Mezger doesn't have heaps of oil control issues. And in the US the 996 Turbo and R33 GTR are roughly the same price these days. 996 maybe a bit more now that the hype has abated for old Skylines here.
    • these are not the same
    • Best kept secret for seized bolts is crayons... Heat the sucker up with a torch, and push/melt crayon into it. Works a wonder. See if I can go 2 from 2 for you on how to get your bolts out...
