The LM that recently got sold in QLD doesn't look to be a genuine LM. It doesn't have a passenger airbag or updated dash surround. Is also missing the stickers on the pillars.
But the tag says BT2, very odd...
I thought the LM was based on the series 2?
Edited by vesh
Mine after a strip down and engine rebuild, new Spool 2.8 Crank fitted.......
first startup after 6 years stuck in a Barn...haha
https://www.facebook.com/jim.kirkley1/videos/10204415318461840/?l=4934382056436588595
Yeh after more researching i cannot actually find out if it is genuine. I am not fussed if it is or isn't, she is a nice car. All numbers match up, year is 1996 and has paint code BT2 stamped on the plate. Is there anywhere i can do a vin search or what not to find out if it is 100% genuine or not?
Just wanted to advise that I have purchased a GTR33 V-Spec LM Limited from Kevin,(Livewire). I am eagerly awaiting delivery to Melbourne. I feel privileged to now own such a rare version of GTR33. I appreciate original condition cars, and intend to maintain this car in as close as possible to factory specifications. I think it is great that there is a site on this forum for these models, and I enjoy reading other owners posts.
Hopefully there will be continued interest, as I noticed that the instigator of this site,Chris H .has sold his car.
Ross
  • Like 1
Request:- Re: GT-R FESTIVAL 28th May 2016 held at SMSP.
We require a R33 GT-R LM (V-Spec or Non) for a Display. It can be modified.
It'll cost $30 entry but you'd be the only LM on display. It needs to be in top condition and will be filmed with other GT-Rs on Motive DVD
PM me, as I'm in charge of the Heritage GT-R Display.
Thanks for contributing...
  • Like 1
My GTR 33 V-Spec LM arrived today and I am delighted with the overall condition and presentation.
The car is in excellent original condition and is a credit to previous owners.
Looking forward to a drive and then make arrangements for Vic. registration
  • Like 2
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
