Hi all,
I'm fitting some stock tail lights on my R34 after I got rid of my faded LED pair, and I noticed that the inner set of lights (smaller circle) take a pair of bulbs that I can't seem to find. Correct me if I'm wrong, but are these supposed to light up when the headlights are on?
I've looked around, and the general consensus seems to be that T10 wedge types will work just fine, but they don't seem to fit on the sockets - no click can be felt or heard when they go into the sockets (using 12V 5W T-10mm, capless). I strongly feel that the plugs on the bulb are not long enough to reach the socket's metal contacts.
After fitting them they don't turn on when the headlights are on, but brake lights work when pressing on brake and indicators work fine too. Is there another type of bulb that works with the inner circle? It could also be a fuse problem, but indicators and brake lights are working on both clusters, so I'm really confused about this. I've also tried fitting all four bulbs and then turning on the lights, but no dice.
I've bought enough ill-fitting bulbs to create a shop of my own at this stage. Any help will be greatly appreciated. I've attached a photo to show which part of the light I'm referring to.
Thanks!
https://www.sau.com.au/forums/topic/448368-r34-tail-light-bulbs/
^ Incorrect. They do light up. The inner lights will light when you have your parking light switch on. The brake lights are only the larger outer ones and the center brake light on the boot.
They take, at least one mine, T10 wedge types. Are you trying to fit fancy LED replacement bulbs or stock T10 globes?
Thanks for the reply!
I'm trying to fit stock bulbs, but I've tried T10s and it seems that some of the plastic in the socket that supports the bulb is preventing it from getting to the contacts, hence why it can't light up - the bulb simply isn't long enough. I've contacted the Nissan dealership in my area and they were able to order some in from Melbourne (coming in soon I hope), but I'm not sure what type they are since Nissan uses their own standards for their bulbs
Also, one more quick question- when you turn on the headlights, is the larger circle on the tail light supposed to turn on as well? Or do those only turn on when the brake is applied?
Edited by ninja_102
Ah, I figured it out in the end - the bulbs in the inner circle do take T10 wedge types, if anyone else is looking for them, the width of the both ends of the bulb should be the same - 10mm.
The problem I was having with mine was that the sockets for these bulbs was stretched due to having the LED set in them for so long. All I had to do was pinch the metal contacts of the sockets together with a pair of pliers a little, and after that I was able to make the T10 bulbs fit properly.
The inner and outer circle of lights light up when the headlights are switched on.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
    • Also wanted to say, my new spark plugs are blackened looks like it's very rich. I have splitfire coilpacks but stock coilpack loom and ignitor. I tried directly grounding the ignitor ground to body as well.
