Hi guys,
Sold my 2012 GTR and bought a 2014 Black Edition.
Unfortunately, the exhaust the 2012 GTR had fitted is not compatible with the 2014 Black Edition.
It will fit all 2011-2013 models (excluding black edition).
Accordingly, I have for sale a full GT Haus Miesterschaft Titanium (lighter and more expensive than stainless steel)
system. Includes mid-pipe/y-pipe, muffler etc.
The complete system was on the car for 10 months. Have had no issues.
In terms of sound, it is very loud and aggressive, YouTube is your friend in this regard.
These chase a fair bit of coin especially with the weak Aussie dollar.
I'm prepared to sell it as a package, all up for $4000.
Exhaust is in Melbourne, but I can ship interstate at your expense.
Let me know via PM, post in this thread or contact me on my mobile phone number: 0404 723 6230404 723 6230404 723 6230404 723 623, if you're keen to purchase.
Thanks,
Ali
You'll need Skype CreditFree via Skype
Edited by IOWNU
  • 1 month later...
Hi guys,
This item is no longer for sale, as it was stolen from the workshop where it was being stored along with other exhausts for M cars and AMGs. :(
Cheers,
Ali
Edited by IOWNU
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
