These guys are in Russia and apparently can change the HDD in Skyline and J50 etc, the contact is Alex, I have emailed him to see if they can help us out down under, if you need to maybe shot him an email and see if he will or can as to date I have not had a reply. Saint Petersburg
Contact:Alex
E-mail:[email protected]
Skype:s7alois,
Tel .:+7(962)686-0739, +7(964)397-0189
Solutions for Nissan 2006-2010 model years with navigation on the HDD for the Japanese market. (St. Petersburg)
Many car owners with the release date from 2006 to 2010 come to us with the question of what can be done to my car or better compared with what the manufacturer suggests ??
We have compiled a list of typical services for the following Nissan models for the following cars Nissan c System 06IT (HDD) exclusively for the Japanese market: X-trail, Teana, Murano, Cube, Bluebird Sylphy (JP), Cima, Dualis, Elgrand, Fairlady Z, Fuga , GT-R, Juke (JP), Lafesta, Latio, Leaf (JP), March (JP), Note (JP), Presage, Serena, Skyline, Skyline Crossover, Skyline GT-R, Tiida (JP), Tiida Latio (JP), Wingroad.
WANT immediately noted that the staffing MULTIMEDIA DATA EQUIPMENT INSTALLED ON CARS are extremely fragile.APPEAL TO US WEEKLY customers with PROSBOY REPAIR OR USUALLY recovered after "unauthorized repair" navigation unit. We strongly recommend not to trust the repairs of accidental MASTRERSKIM and master with low skills.
Here is a list of basic services on an exclusive order of demand, according to requests via our website:
- Complete replacement of standard equipment EQUIPMENT FOR THE YEAR 2012-2014 c drive HDD (replacement monitor head unit wiring. Coherence buttons on the steering wheel and instrument panel). At the exit you will get an excellent factory system, which will support all the old features and add new ones.
The report and video from such work (
- Unlock video in motion. The service provides the ability to stream video on the move.
- Flashing on European radio broadcasting frequencies.
- Russification panel dashboard.
- Installation of digital TV tuner DVB T2 c function media player (would play any video / audio files on a regular device). The tuner allows you to view the top 20 channels in perfect digital quality broadcasts at speeds up to 40 km / h.
- Connect the camera to the front view head unit.
- Connection and output video images from video-logger or with tire pressure sensors on a regular monitor Nissan.
- Increase hard disk c 40 GB and 60 / 80GB.
- Repair of standard equipment. We are ready to repair any standard equipment. We regularly bring "recessed" equipment or entire vehicles.
  • Like 1
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
