i got a hybrid cooler 600x300x76 with 2.5" piping, from a group by off here, for 1100 that was really worth it, it might not be hks or any top jap brands but hey it works like no different to me and really improved the cars air flow etc... for the money well worth it IMO...
cheers...ben.
https://www.sau.com.au/forums/topic/45253-which-cooler/#findComment-922866
any decent intercooler upgrade will deacrease lag because it improves air flow (by deacreasing resistance) I like the Trust chillers but there are heaps of other good ones, depends on what car you have ? What mods you have/are going to have and what use you are going to putthe car to.
I don't agree with any decent intercooler will decrease lag.
Slightly more lag will be present with an upgrade over a stock IC as there is more volume to fill before pressurising. It takes time to fill a larger area.
However, I can see more power being made with the upgrade FMIC as with the stock IC it impedes airflow hence the turbo has to work harder to get the same air flow to the plenum or PSI to the plenum if you like.
With a higher flowing FMIC the turbo may only be pushing 13psi to get 12psi at the plenum, this results in lower air temps.
The stocker may offer such a restriction at x airflow that it requires the turbo to push 17psi to see 12psi at the plenum.
If you are comparing one FMIC to another FMIC I can see a good one decreasing lag as the good one may have better designed internals, better matched piping size.
There is also an argument that a bar and plate FMIC creates more lag than a tube and fin FMIC as the bar and plate has more internal surface area hence creating more turbulence and air flow restriction.
To a certian extent this is true BUT if you are simply looking at lag a 580hp bar and plate will be smaller therefore have less volume compared to a tube and fin FMIC that can support 580hp.
So the way I see it there is probably a bee's dick difference between the extra resistance the bar and plate creates compared to the less restriction but longer time it takes to fill the larger tube and fin FMIC.
Stick with the stock 2.5" piping.
As Gary (SK) once posted 2.5" will flow up to around 600hp before becoming a restriction to airflow. It was some where around 600hp. :D
My FMIC is a bar and plate close to 100mm thick, it apparently supports 580hp with a 1.5psi pressure drop. Will be interesting to see if it lives up to those figures, i'm only looking to push 500hp, maybe 550hp occasionally through it. I think 550hp is pushing the stock rods to close to their limit.
I havn't seen R32's that are stockish bit of boost etc... pick up much power with a FMIC but for some reason the R33's even with stock boost pick up a decent gain in power.
https://www.sau.com.au/forums/topic/45253-which-cooler/#findComment-923918
Hi guys, here is an example of 4 intercooler setups and pipework we have actually used;
1. R33 GTST Standard Intercooler and standard R32 GTST pipework
150 rwkw = 27 lbs of air per min @ 13 litres of i/c & pipework
2. Supra Intercooler and matching 63mm pipework
180 rwkw = 30 lbs of air per min @ 15 litres of i/c & pipework
3. Standard GTR GTR and 63/75mm pipework
250 rwkw = 40 lbs of air per min @ 21 litres of i/c & pipework
4. Greddy 600 X 300 X 115 and 80 mm pipework
400 rwkw = 60 lbs of air per min @ 28 litres of i/c & pipework
If you look at the numbers you can see that the rate of air flow and the volume of I/C and pipework have a fixed relationship (27 = 13 , 30 = 15 , 40 = 21 , 60 = 28). This is not an accident, I designed it that way. The reason is I wanted to keep the throttle response as close what it was when the car had 150 rwkw, because I though that was very nice response.
The theory I followed was, the more power the engine produces the more air it needs. Thus if I keep the increase in the volume of air inside the inlet system in the same proportion as the power increase, then the throttle response should stay the same. This is based on the engine using the air in the same time frame.
So when people say they fitted a FMIC and have not noticed any less throttle response, my response would be, that is what I would expect. As long as they went from 150 rwkw to 180 rwkw. On the other hand, if there was no power increase then it would be simply physically impossible for there to be no decrease in throttle response.
The problem of poor throttle response arrises when you have a 220 rwkw engine with a 28 litre inlet system. This is something I see way to often.
Hope that adds to this interesting thread.
https://www.sau.com.au/forums/topic/45253-which-cooler/#findComment-923937
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
