Zele International LED tail lights for R34. Look very similar to Nismo (see attachments below).
Some of the LEDs on the outer edge of the outer lights are not working. Needs to be taken apart and connections checked or LEDs replaced or something - I haven't looked into it in a lot of detail.
For the Japanese readers, see the installation manual attached - also has pics of what the light look like when running.
Looking for $700 + shipping
Alternatively, if you're handy with electronics, I'll pay you to fix them.
SMS 0407778421 or PM
  • 6 months later...
All parts are stock and off a 130k km R34 GTR
Turbos $300
- were boosting fine when on car (running at 1 bar on e85 for 8k kms and standard for remainder)
- come with standard actuators
- can't judge shaft play, but assume there will be some given kms
- standard R34, so ceramic exhaust wheel
Dump pipes $300
- come with heat shields
- also include O2 sensors
Inlet piping $100
- rubber piping that goes from turbo to stock air box
Will sell everything together for $600
PM or SMS on 0407778421
Parts in inner west Sydney. Prefer pick-ups
  • 9 months later...
  • 6 months later...
