  • 1 month later...
well i put together my new gearbox hoist and put the GTR box on it lifted it up and over the weekend im going to make a custom crossmember to install the box with the custom made front and rear propshafts. Also got another cossy to GTR bellhousing made and ready to go on my spare gearbox. and lastly i have a cosworth bellhousing and a GTR bellhousing to (if needed make a 3rd one) as i have 3 GTR boxes.
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
