Carbon Fiber Group Buy #2 R32/r33/r34/r35 Evo Etc 2/4/15 New
markk : the price for 60mm twin gauge holder's is $180
Swole : which back was it ? FRP , Glitter , cf kevlar
okooko :
R32 AB flug lip $310
R32 TS rear diffuser : $580
Darmanin10:
R32 GTR radiator cooling panel $140
R32 GTR/GTST mirror cover $160
RB26DETT coilpack cover $ 180
R32 Jun Lip $300
R32 AB Flug Lip $310
R32 N1 boot lip $210
shipping fee for both is roughly $40-$70 when combined together to sydney
Longz : R35 varis vents , emblem cover , exhaust shroud , bonnet scoop , front grille , engine cover , center console , top secret front lip , zele side skirts
.:: GimpS-R34 ::. : * R33 GTR OEM rear bumper exhaust shroud - *RB26DETT coilpack cover
nism26 : R34 wing stands and r34 door sills
IcedTea : R32 CF Cooling Panel
OYEAHA:R34 canards 4 pieces
will34: r32 cf rad cooling panel
Longz,
Any pics of the R32 GTR Abflug carbon fibre front diffuser? Does it come with any mounting brackets?
What's the quality like...
Price?
Cheers
Swole :
Bride Stradia II :
FRP :$800
Glitter : $840
Carbon or Kevlar : $1200
includes shipping to Sydney
suwidji : Sorry missed you !
r34 gtt eyelids cf $90
there are no z tune side skirt's for r34 gtt only GTR
asura : which one ?
R35 Spoiler list
OEM Spoier
Voltex Type 5 1600mm or 1700mm Spoiler
OEM Spoiler with raised legs
E Spirit Spoiler
Amuse Spoiler with raised legs
Bensopra rear spoiler
Revozport boot spoiler
Asura : they have the voltex spoilers that look similar.
Msr: they have side skirt's for the evo you can modify as universal
pureplaya: r32 gtr AB FLUG
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
