Ok so it’s been 2 weeks since the old girl has moved on and hopefully settled down ok with her new owner. Still a bit shattered that she’s gone, but that’s life and time to move on…
So on that note, it’s also the time to move on some new and old parts that are now taking up space since I will no longer use them.
This thread will get updated with more parts as I get a chance to go through them all, or if I have new pictures to post up, or if shit sells (will be removed)… So be sure to check back smile.png
Now I ain’t holding shit for no one as I’ve been burned before. First to come up with the cash will get the goods. Too easy biggrin.png
Also you’ll note in the following, prices are ono (or nearest offer). Doesn’t mean I’ll give them away for nothing. An item or two will be firm, and if it doesn’t state “or posted via Express Post” then I’m not all that keen to post due to the size or weight of the item. Be warned, low ballers will be ignore or cop a barrage of abuse. Simple rolleyes.gif
Ok so for the goodies in no particular order (most are Silvia stuff and initially posted in ns.com, but hopefully may apply here too, there is one item which is Skyline related, that being the R33 GTS-t Handbrake Cables :laugh:)
Genuine Volk Rays Eng TE37 (Matte Black) - Staggered - $3000ono pick up
Check this thread for full details: http://www.sau.com.au/forums/topic/453801-genuine-volk-rays-eng-te37-matte-black-staggered/
Genuine Origin Carbon Fiber Door Visors (used, but as new – mint condition) - $200ono pick up
This has been trimmed to fit an RS13/RPS13 (180sx). Origin didn’t make this for the RPS13, but only for the S13/PS13 (Silvia). As per picture, it has been trimmed and cuts off at the door. It still can be fitted to a Silvia, but it will also cut off at the door (won’t continue onto the quarter windows).
Genuine Ikeya Formula Tie Rod Ends S13/S15 (BNIB) - $350ono pick up or posted via Express Post
Pictures tell all. Brand new in box. Never been used.
Genuine Apexi Power Intake 500-A022 (BNIB) & Apexi PS13/RPS13 SR20DET Adaptor (used, but as new) - $150ono pick up or posted via Express Post
The 500-A022 will fit both Z32 AFM and PS13/RPS13 AFM with the adaptor. It has the bolt locations on the filter to suit either ones. I bought this in anticipation to fit up to a Z32 AFM when I was going to do a turbo upgrade, but never got around to doing it.
Included in this sale is the PS13/RPS13 SR20DET metal adaptor.
Refer to pictures, should tell all.
Genuine Nissan R33 GTS-t Handbrake Cables (BNIB) - $150ono pick up or posted via Express Post
Pictures tell all. Brand new in box (plastic). Never been used.
Genuine Nissan RPS13 Type X Side Extensions L&R pair (BNIB, although I got them painted stock Type X white colour code 326) - $150 firm pick up or posted via Express Post
Bought these brand new from the US a few years back. As most on ns.com know, I’m anal as it gets and got these to replace the ones I had on the car because one of them had a slight flaw on a section where it meets and double tapes onto the front guard so it didn’t sit 100% flush against the guard. Anyhoo, I got them sprayed stock Type X white (colour code 326), but never had the time to fit them up. Still has the original Nissan double sided tape untouched.
Note that the pictures are unpainted. Pictures were obviously taken prior to getting them painted. Will get current painted pictures next time I get a chance.
Genuine Nissan RPS13 Type X Front Bar to Side Extensions Brackets L&R pair (BNIB) - $70ono pick up or posted via Express Post
Similar to the above, I bought these at the same time as the Side Extensions and wanted to fit up at the same time. Never got around to doing it. They are brand in new box (plastic). Note that the 2nd picture with the red background is not mine and just for reference, since my actual pictures are still in the plastic and hard to see.
These are basically the brackets that bolt onto the Type X front bar to bolt up onto the front guards, to meet the Side Extensions.
If you want these together with the Side Extensions, will let them go for $200 the lot.
Genuine Tomei Dump Pipe with EAI (EGR) for PS13/RPS13 SR20DET (BNIB) & Genuine Nissan EGR Pipe (BNIB) - $350 firm pick up or posted via Express Post
These are now discontinued!
Bought this thing a few years back to fit up (again, never came around to do so) in the attempt to make my car Popo and EPA friendly. This Tomei Dump Pipe has the section to maintain the EGR, unlike the typical standard Tomei Dump Pipe without it and many of the copies floating about. I also bought the Nissan metal EGR pipe brand new as it’s almost impossible to remove and reuse the old one from the stock dump pipe as it is usually fused on after thousands of heat cycles.
Will also include the stock EGR set up if you want the bits as well.
Pictures should hopefully do the talking!
HPINABOX T25>T28 Turbo Clocking Adaptors (BNIB) - $50 firm pick up or posted via Express Post
I’m sure the interested buyer will know what this is and what it’s used for. All others, it’s to allow the inlet and outlet of the T28 turbo (GT2871R, Disco Potato etc.) comp cover to be clocked at an angle to be a direct bolt on for our beloved PS13/RPS13 SR20DET that utilise the T25 turbo.
Midnight Mods PS13/RPS13 SR20DET Braided Turbo Lines (brand new) - $150ono pick up or posted via Express Post
Brand new/unused. Didn’t state BNIB as it doesn’t come with box tongue.png
Picture tells all…
Genuine Nissan T25>T28 Turbo Gasket/Bolts/Washers/Nuts/Screws/Drain Pipes etc. Kit (BNIB) - $TBA pick up or posted via Express Post (still need to properly add up all the prices to be able get a “kit” price, but food for thought I spent around $400 for the lot so will likely be around the $300-$350ono mark)
Here we basically have ALL the ancillaries to do a turbo upgrade the proper way. EVERYTHING to fit up on a PS13/RPS13 SR20DET (and can also fit S14/S15 if you +- some parts).
Again to show you how anal I am, I bought all new gaskets, bolts, washers, nuts, screws, drain pipes, the whole shebang to replace every single part when I set out to do my GT2871R turbo upgrade, which sadly never eventuated.
I got all the parts with my own extensive research and cross referencing with Nissan FAST, so I know that each and every single item in this kit was going to fit onto my RPS13 SR20DET (180SX) from the block (exhaust manifold) to the dump pipe. I was prepared to replace all the old ancillaries for brand new.
Do it right the first time right?
Check the pictures to see all the bits and pieces included. Note that the exhaust manifold gasket is the more expensive 7-layer S15 one, rather than the cheaper PS13/RPS13 one.
Various Genuine Stock Nissan Parts for PS13/RPS13 SR20DET (used):
Here’s a list of stock parts for defect, RWC, and EPA/emissions purposes. I kept or bought all these parts over the time I had my car in case I ever got the dreaded defect (as everyone knows, Victoria is the granny state). These parts were my saving grace as I was able to use them to get 3x defects and 1x emissions test cleared without too much problems!
Will get pictures up (hopefully) by the end of the week.
Stock exhaust (great condition). Everything is intact, including the exhaust tips - $200ono pick up
Stock suspension. Last used was about 2010 to clear a defect and was in good condition. Been sitting in the garage since - $100ono pick up
Stock SMIC (good condition). Pretty sure it is all complete all the way to the throttle body (i.e. cold pipe). Hot pipe not included as that went with the car - $50ono pick up
Stock EGR (good condition) - $50ono pick up
So yeah, that's it for now. I'll post up more shit when I locate them so remember to check back regularly!
Send me a PM for any interest, or shoot me a text on zero 421 one two one 8 one 8. Location is Burwood East, VIC for pick up.
Cheers,
Andy
Bump...
Pictures of the stock bits as below. As you'll see, all in tip top condition!
Included for free is the dump and front pipes, and exh manifold. Note the pic of the front pipe and exh manifold are still wrapped up in the blue plastic. Couldn't be fkd unwrapping, but I'm sure you know what they looks like.
post-25413-0-60761800-1426493817_thumb.jpg post-25413-0-60482300-1426493822_thumb.jpg post-25413-0-16458000-1426493828_thumb.jpg
post-25413-0-35324800-1426493831_thumb.jpg post-25413-0-01204500-1426493834_thumb.jpg
Again cbf'd unwrapping the plastic. Front suspension you should be able to see through the clear plastic to get an idea. One rear has been unwrapped from the blue plastic, the other is exactly the same.
post-25413-0-51148200-1426493871_thumb.jpg post-25413-0-36220400-1426493875_thumb.jpg post-25413-0-32560500-1426493879_thumb.jpg
Stock airbox with filter (good condition) - $100ono pick up
You get the stock air intake for free!
post-25413-0-23673400-1426493900_thumb.jpg post-25413-0-35013400-1426493905_thumb.jpg post-25413-0-00472000-1426493908_thumb.jpg
Cheers,
Andy
  • 1 month later...
Genuine Nissan RPS13 Type X Side Extensions L&R pair (BNIB, although I got them painted stock Type X white colour code 326) - SOLD!!!
Genuine Nissan RPS13 Type X Front Bar to Side Extensions Brackets L&R pair (BNIB) - SOLD!!!
Rest of the other stuff still for sale. Prices are ono (or nearest offer)!
Cheers,
Andy
Love when people put in the effort with good pics, clear and consise info. Good luck with the sales
Everyone else take note this is how you should sell your shit
^ Thanks mate :D
Also saves me time and effort in needing to further explain or get clearer pictures. Do it right the first time, as time is money... And on that note a few updates...
Stock airbox with filter (good condition) - SOLD!!!
Stock EGR (good condition) - SOLD!!!
Genuine Tomei Dump Pipe with EAI (EGR) for PS13/RPS13 SR20DET (BNIB) & Genuine Nissan EGR Pipe (BNIB) - SOLD!!!
Cheers,
Andy
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
