Up for sale is my CBR250RR MC22 which I've owned for over 2 years.
1991 Imported in 1997 I'm the second owner in Australia.
CBR250RR MC22
In my ownership I've done the following :
New tyres front & rear (michelin pilot power) (4000kms old)
New front pads (1000kms)
New complete rebuilt forks (1000kms)
New front & rear wheel bearings (4000kms
New steering bearings top & bottom (1000kms)
Adjusted & lubed chain
Spark plugs
Air filter
Oil filter
Oil all done 2 weekends ago less than 200kms
New OEM honda blinker switch block (8months old)
New OEM fuel tank rubber mounts
New EBC CK series clutch kit
New EBC stiffer clutch springs
Yoshi look-alike exhaust
Red LED cluster globes
Tyga carbon fibre cluster surround
Tinted visor
LED rear blinkers
Spare set of keys
few other little things which I can't remember.
Everything works perfectly as it should and for a bike of this age its in exceptional condition. Starts perfectly dead cold or hot weather. No weird sounds, rattles or knocks. Never been dropped or smashed within in my ownership.
Fairings in a 9/10 conditon besides a crack on 1 side.
Gets about 220kms to a tank on 98 before having to switch to reserve.
Would like a quick, hassle free sale, negotiable slightly but no time wasters.
EBAY : http://www.ebay.com.au/itm/161619380056?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1586.l2649
BIKE SALES : http://www.bikesales.com.au/private/SSE-AD-3279045/1991-Honda-CBR250RR
GUMTREE: http://www.gumtree.com.au/s-ad/fairfield/motorcycles/honda-cbr250rr-mc22-fireblade-lams-approved-runs-like-a-dream/1072188575
Located in Fairfield 2165.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
