The car starts up fine but the sound coming from the head is super unnverving. I'm wondering if I have a bent valve or something. I pulled the covers and I saw no sludge or anything. The oil is super clean (I changed it last summer and put 20 miles max on the car. it hardly gets driven). I know its tough to gauge what could be wrong with the vehicle based on sound but here is a video of the noise. Remember this noise is speed dependent.
https://youtu.be/HWnxb16Bfr4
What would my next course of action be? Would a compression test tell me if I have a bent valve or anything? She starts and idles fine and drives fine although the only driving I do is from the end of my driveway back into my garage. Took the valve covers off to see if I saw anything irregular such as sludge or anything but everything is super clean. Like I said since putting this motor together, i've put a maximum of 100 miles on it in 2 years since I finished the car.
I'm from the states but I figure I would ask you guys because you guys see these motors more than we do here in the states. Any info would be much appreciated.
Sounds like there's two different noises, one when put under sudden load at 0:05 which sounds like a knocking, that noise ive never heard before, the ticking noises I would bet are the lifters , maybe a few have collapsed and not pumping back up..
What was done to the head/motor when built? are you using big camshafts?
Brief history of the car. Did fresh internals of the motor. Bottom end was completely worked over. Head is just ported and polished. I put it in the car and life happened and so the car sat more than it was driven. Camshafts are stock. I want my toy back so I am starting to get back into the car. I believe the timing might be a tad off so that could be the knocking you hear. I'm hoping the ticking/knocking is lifters. I plan pulling the lifters this week and seeing if I can clean/revive them. and putting things back together. I also notice that one of the bolts was snapped off the cam angle sensor.
Its been so long since I've worked on the motor that its kind of scaring me to get back into it. Mainly getting the timing right such as getting this at TDC and what not. I've read that I don't want the motor at TDC when I reinstall the cams. It's scary stuff to get in to. The last go around I had someone who knew what he was doing but he has since moved away. It also helped that the motor was out of the car. I'd rather not have to pull the motor if all I am fixing is lifters and timing the motor correctly.
Does it have good oil pressure and the right viscosity oil?
I've always put 10w30 in it but might oil pressure gauge is a little suspect (it was used). I'll buy a new one right now. 10w30 is the correct oil I should be using correct?
Yeah my thinking is that when the lifters are held under load and sit for long periods is they get bled and stick in position? so will probably need taken out and soaked then pumped up with fresh oil,
There's heaps of threads on lifter problems on here and someone else might have more advise, but if mine id flush, then new oil, get the engine hot and let run for 20mins and see if the lifter free's up, keeping the revs low to avoid damage, but its your call really.
Edited by AngryRB
Yea thats my plan. Ill take the lifters out and work them as best as I can and then reinstall and see where that takes me.
Edited by Inline6Silvia
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
