Brand new Forced Performance gt3076r.
Change of direction in build.
Located- Wangaratta 3677
Buyer pays post or pick up.
Price- $1800
Contact on here or on 0400215126
Cheers Josh
https://www.sau.com.au/forums/topic/455960-forced-performance-gt3076r/
Bump make a reasonable offer
Alot better than a gtx and gt series. Proven to make near on 400kw atws with killer response.
Edited by Joshbigt62r
1600 dollars maybe still slightly be negotiable. Try me. These are 2k us before shipping so im losing here but need to move it for other plans.
Josh
Makds more power and spools faster. Read the Forced performance thread on sau. This hta76r kicks ass on a rb25.
I can confirm this :yes:
If anyone has any doubts check either my build thread or Wootten Racing on Facebook to see dyno graphs, dyno videos and any other info.
With the USD the way it is it makes this turbo extremely good value!
GLWS mate!
  • Like 1
Thanks matt. It was your build that influenced the way I was going. Unfortunately things have changed and I have to sell u p :(
I honestly cant believe this hta76r hasnt been snapped up yet. There 2k US Then you have to pay import taxes ect. In my opinion its the best rb25 turbo you can get.
  • Like 1
Come on guys $1600 is a bargain. I dont think people understand just how ultimate like this turbo matches a rb25. Even a single rb26 its good for 400kw at the wheels pretty much with killer response.
Just to verify it comes with no rear housing. But the kando tear housings are like 200 bucks in which ever size duits you .63 .73 .82 and 1.06
upgrade your standard cast wheel old school gt3076r to this weapon billet quick spooling anjmal of a turbo.
SOMEONE BUY THIS FFS. lol
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
