The following parts came off my R34 GTR V-Spec, and all prices are slightly negotiable. Lowballers will be ignored
1. Stock R34 GTR Tail lights - $150
2. 2x Lambda o2 sensors for R34 GTR, Used but still in good condition and works. - $80
3. OEM Twin Turbo pipe - $50
4. Xforce R34 GTR dump pipes, used but in VGC, jsut needs a polish and will come out brand new - $250
5. Unknown brand RB26 Camgears - $100
6. 2x HKS Mushroom filters, Used (does not come with the pipe attached to the pod filters) - $60
7. Unknown brand front brake pads (Came off my R34 GTR Brembos), still have plenty of meat left, only changed because a good deal came up on Pmu pads. - $120
8. R34 GTR Cusco Brake Stopper - SOLD
9. Tomei Type B poncams 270 degrees 9.15 lift (these were made in limited quantities, they are not listed on the tomei website but they are 100% genuine, someone on SAU has contacted Tomei regarding it and confirmed they were a limited run.(http://www.sau.com.au/forums/topic/219857-building-an-rb26-for-response/?p=7205516), only reason i'am replacing them is they don't suit my setup needs so i have downsized to Type A poncams, these have done less than 10,000kms and are currently on the car due to be removed on the 20th of this month, if you are interested in this item i'm willing to take a small deposit and put the item on hold for you) - $600
10. Garrett -5 turbos with actuators (coming off car on 20th May, have done around 15,000kms, not sure of condition but still works fine on the car, and open to inspect them, willing to take deposit to hold onto them for you) - $1300
11. Nismo Horn Button - Used but in VGC condition - SOLD
12. OEM R34 GTR V-Spec Stock Suspension - used but no leaks - $80
13. 2x NISMO AFM's (Used, was sold to me broken by a SAU member, plugged it in and came up with no voltage when tuned, all mounting tabs are still intact and in perfect condition, could be a easy fix with soldering inside, but don't know, dont want it sitting around so might as well try sell them) - $100 (Pending pickup)
Contact me on 04228844 eight three
Located in Warrick Farm NSW
Pickup preferred but will post at buyers expense
Cash or bank transfer only, no Paypal.
11149274_10206558061568522_323737469316111139986_10206558060368492_169325912358311101066_10206558061528521_550729119287010404285_10206558060928506_342373831766811052481_10206558061048509_113754458046311262408_10206558060648499_582239255491913392_10206558060688500_110958939818711321883_10206558061488520_446096298424582411223958_10206558099729476_8997095647693
https://www.sau.com.au/forums/topic/456580-assorted-rb26-parts/
UPDATE #1
1. Stock R34 GTR Tail lights - $100
4. Xforce R34 GTR dump pipes, used but in VGC, jsut needs a polish and will come out brand new - $200
5. Unknown brand RB26 Camgears - $80
6. 2x HKS Mushroom filters, Used (does not come with the pipe attached to the pod filters) - $50
7. Unknown brand front brake pads (Came off my R34 GTR Brembos), still have plenty of meat left, only changed because a good deal came up on Pmu pads. - $100
9. Tomei Type B poncams 270 degrees 9.15 lift (these were made in limited quantities, they are not listed on the tomei website but they are 100% genuine, someone on SAU has contacted Tomei regarding it and confirmed they were a limited run.(http://www.sau.com.a...onse/?p=7205516), only reason i'am replacing them is they don't suit my setup needs so i have downsized to Type A poncams, these have done less than 10,000kms and are currently on the car due to be removed on the 20th of this month, if you are interested in this item i'm willing to take a small deposit and put the item on hold for you) - $600 (PENDING DEPOSIT)
13. 2x NISMO AFM's - SOLD
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
