Hey guys just a noob question here... When we dropped the engine into my R32 rb20de some how two pipes got stuffed up on the plenum and no one can seam to figure out how haha..
These two pipes on the plenum were are they meant to run to ?
And the second one is a little valve on the back of the plenum?
Thanks for any help in advanced.. Last thing left on this build!
https://www.sau.com.au/forums/topic/457418-plenum-pipe-issues/
The upper one on the plenum goes to the nipple where the plenum meet the head right at the upper right of the cylinder one runner.
The lower one goes to the water pump if my memory serves me right. I need to check that on the pics I got. Will confirm this later.
The little pipe on the pressure regulator need to be plugged into the plenum. There is apparently to type of fuel rail on the rb20, one with only one fuel pressure régulator at the exit, and a second one with one at the entry and a second at the exit.
Both need to be pressure referenced to the plenum.
Well with the top pipe removed you don't feed water to the "water rail" on the top of the runners, so it seems that the intake manifold gasket is leaking. Pretty badly I'd say if making the water flowing in the bloc/head is sufficient to fill the cylinder.
Would it matter / cause Any damage if I was to keep this perminatly blocked off?
That is until a later date that I redo all my gaskets.
Bearing in mind the engine is only being used on the track for 60km sprints one a month?
Cheers.
If you do not have the problem without the upper hose, it means that the coolant circuit is not bleeded properly so you can't run it like that.
If you do it anyway, the gasket could broke entirely and you risk a hydrolock and/or an overheating of the engine because of the non bleeded coolant circuit.
So no it's not really a good idea to run it like that.
All right looks like I rip the plenum and air intake manifold off this week and find the issue :3 cheers for your help!
Just found a oil leak too... Is there a easy way to get the oil filter housing off without removing the engine ?
This is the gasket where the runner meet the head that need to be changed not only the upper part of the plenum.
Once the runners off you'll have all the space needed to fix your oil leak too.
Os for the hoses yes it's right the way it's is plumbed. This is the idle/fast idle air circuit.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
