apexi avcr - brand new opened to have a look and then put into storage. $500
apexi bov - rare packaging from japan still intact, unit works fine is in used condition. $250
r34 gtt or gtr fog lamp brand new genuine never used $150
r34 gtt airbox and snorkel used condition $150
r34 grill - fpr series 2 bumber i believe or some aftermarket bumpers, $200
rays volk racong f zero challenge rims tyres like new size (2 x 17x8) (2 x 17x9) offset +40 all round sit flush with gaurds. $750
roh internation prowlers 20 inch, near new tyres, $750
Edited by ReeceGTS-T
Thanks for that mate I'm also very interested in your avcr it is the black edition yeah? It does contain everything yeah? Will talk soon if not sold before hand!
yes limited black edition but they are not that rare easy to pick up but are retailing still at around $750 plus. no worries send me a PM when you are getting serious about buying. no holds.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
