Hi guys and girls, I have decided to go for a single turbo while my engine is out and to fund it I am selling off my full twin turbo setup.
Now it comes with everything you need to literally bolt up to your stock rb26.
Including HKS 2540 twins (flow a little more than hks2530s at moderate boost levels but really come to life when u really wind the boost up)
I made 305kw@wheels on 17psi untuned, I wound them up to 24psi and had massive top end rush from 5k onwards and held all the way to my 8300rpm limiter. So, great for drag racing but not the best for tight hillclimbs etc.
The turbos have zero shaft play, or damage. I am simply going Single while my engine is out. Come and inspect, they come with HKS actuators and studs, manifolds and even oil lines if you require them. $1300
Next is the exhaust system (Xforce split dumps) Stainless. perfect condition. $250
HKS midpipes. twin 2.25 into 3inch ($300
3inch catback exhaust its on my r34 but came off a 33 gtr. ($300
and to aid in response and flow I have a custom twin turbo pipe with divider added $200 (eliminates turbo shuffle and improves response)
Or the whole lot as a package for $2100.
I can post anywhere you like. located Newcastle NSW
Cheers fellas,
Blake
attachments (1).zip
attachments.zip
Need money for a to finish my build! Buy my stuff :)
Turbo's $1000
Dumps $225
Midpipes $225
Exhaust $250
Split twin turbo merge pipe $200
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
