Gtr33/34 Ohlins Mines Coilovers,serial 3 Gearbox, Rb 26 Head,block,new Cp Pistons And Eagle Rods, Yoko Semis
Selling off my spares, track car is going good, I hope I wont need them
Item 1, Ohlins Mines adjustable coilovers, front part #CT5-S0100-70,Rear CT5 S0200-70 with Mines revalving,Mines ESTA springs. Mines tuning house is reknown for drivability and comfort. GTR33 did 1:46 at Phillip Island,I have bought Ben's ( Racepace founder) Tien RS/RA. Hope the car can go faster.
$1500
Item 2 .GTR33 serial 3 gear box out of a 97 model with 65000km. my OS Giken closed ratio is going good,no need to keep spare
$1500 ono
Item 3. RB26 block GTR33 crank, matching girdle , machined, balanced, cleaned,deck,etc.etc with New CP Pistons 87mm and Eagle Rods. $2900.
Item 4 RB26 GTR33 stock rebuilt head ready to go into the above Item 3. $1600 Can arrange assembling
Item 4 number of Yoko A050 265/35/18 good for practice and sort out car,2 Kumho S70 255/40/17 40% thread .$30 each. pick up from Braeside 3195
Best to sms/call Alex 0433878905
Bill will have first dip with long forged motor package going into a GTR34.
Got a pair of HKS 2530 with dyno time only, I have gone single turbo. $2200, no actuators.
Brand new ATS treble carbon push type clutch still in box from Negan Japan.. cost $4200 landed. best offer over $3500. I have put a Nismo super copper mix, excellent clutch on my track car.
Any proof that 2530's are new apart from dyno time, Are they recently bought with a reicept?
Where are the Wastegates?
I have gone single for my track car,it is a lot easier to work on, actuators were sold ,Bought these off a mate who also gone single,sorry no receipt as I did not buy them from HKS dealer CJ Motors. I have also put a pair of 2530s replacing a T88-38GK to make one of my GTR33 street legal in Victoria.350kwaw on 98 pump fuel. The core is Garrett -5, 2530 has its own HKS housing which flow better.that the only difference
Got a 300zx 5 speed gear box in very good condition $800, gear set is same as RB 25 box, I have gone with RB25 box conversion with Speedtech close ratio gear set. Looking for a broken RB25 box to swap gear set over as spare box. Anyone in Melbourne has got one?
Alex 0433878905
looking for Ikeya sequential shifter for GTR 33 5 speed box with OS Giken gear set and Front lower control arms with roll center adjustment spacers. Hardrace brand or Ikeya
  • 1 month later...
  • 3 weeks later...
got a set of upper and lower Ikeya front control arms from Bill. Thanks
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
