2000 Black Rs4S Stagea dayz edition
genuine factory manual 140,000kms
Engine and Exhaust:
Hks panel airfilter
Turbosmart Kompact Bov
Z32 Bosch AFM
Apexi Turbo timer
Splitfire coilpacks
Apexi power fc with hand controller
3inch turbo back exhaust
550cc fuel injectors direct bolt on
Walbro fuel pump
Apexi ax53B70 380hp turbo (braided oil lines)
Silicone turbo intake pipe
Oil cooler/oil filter relocate
100,000kms service with all genuine Nissan parts
Handling and braking:
Gt-r 33 suspension
Neotech adjustable rear camber arms
Cusco brake booster stopper
Nismo longer wheels studs rear
Gktech wheel nuts
Gktech braided brake lines and custom hardlines
Full set r34 4pot front and 2pot rear brake cailpers painted red
T3 dba slotted brake rotors and Qmf hpx performance brake pads
Information on car:
I’m the first owner of this car in Australia, brought from dealer in Sydney back in 2010 completely stock except for exhaust and coilovers. I purchased car with 74,000kms and was my daily drive car and use to do average of 800kms a week! Majority was highway kms. Car has been garage last year as its been used for a weekend car. Car has been serviced every 5,000kms with full synthetic oils, front diff rear diff and gearbox oil have also been changed. great fun car to drive, never had a problem, these things are coming rare to find especially in this condition, heap of receipts for work done.
The bad:
Two rear luggage hooks are broken
one of headlights has a crack
front right wheel bearing is ticking
car could use a good detailing
check engine light is on, due to apexi hand controller easy fix heres the topic for more info
http://www.sau.com.au/forums/topic/175032-power-fc-in-a-25t-rs-four-s/#entry3208663
car is located in Gold Coast Queensland
Price: $10,500 no rego no rwc towed or on trailer.
or $13,000 with all of the bad above fixed fresh 6 months rego and rwc.
0430055337 No swaps
post-77025-0-80980600-1443580272_thumb.jpgpost-77025-0-90696300-1443580292_thumb.jpgpost-77025-0-26061100-1443580312_thumb.jpgpost-77025-0-62405500-1443580334_thumb.jpgpost-77025-0-23013200-1443580357_thumb.jpgpost-77025-0-27516800-1443580397_thumb.jpgpost-77025-0-22973000-1443580428_thumb.jpgpost-77025-0-29811600-1443580454_thumb.jpgpost-77025-0-17468000-1443580471_thumb.jpgpost-77025-0-30859600-1443580904_thumb.jpg
Edited by shotpointblank
https://www.sau.com.au/forums/topic/460062-fs-stagea-rs4s-black-dayz/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
