as tittle.
$200
these are shorter than stock arms giving neg camber.
genuine and in very good condition
i have no use for these any more so i am open to offers
will post at buyers expense
inbox me
  • 6 months later...
Hi,
niZmO_Man used to own these and Ravi says the bushes were in very good shape.
The subsequent owner said that he had to take them off according to an inspection.
Both Ravi and the next owner were puzzled by this.
Furthermore visuals reveal no cracking.
If you're near Sydney I don't mind if you try before you buy at $160.
If you're interstate I'll try to take 8 close up pics before you'd pay $180 (incl postage).
That's very fair eh!
Hi,
I'll grab them then terry as I'm from Newcastle but will be in Sydney tonight if you are available :)
Will send you a PM
You have first dibs Josh. My Inbox is partly sanitised - lol.
PM me as I'll be at North Rocks tonight. I'm attending a meeting and it'll be easier there than the Blue Mtns.
