25GT has no turbo. 25GTT has a turbo. I think. Don't quote me on that.
Seriously, most of the interior and exterior (Bumpers, skirts etc) are the same, as they are built on the same chassis. The main differences is the engine, brakes, suspension, and diff.
https://www.sau.com.au/forums/topic/462873-25gt-vs-25gt-t/#findComment-7682750
