Hello, I have recently fitted new Yellow jackets coil packs and plugs. Car runs fine but the check engine light aswell as TCS and slip light are on. Connected a ECU talk cable and the fault code is Code 21 ignition signal primary. I have tried clearing it and also disconnecting battery with no joy. Plugs were gapped to 0.8mm. Engine is a RB25DET NEO. Any help would be greatly appreciated. I have done a search and all results state faulty coil packs. Is there anyway i can check each coil pack with a multimeter?
https://www.sau.com.au/forums/topic/463400-engine-light-and-code-21/
