As title states, I have 3 cars for sale .
1. Honda S2000 $40,000
1999 model
Australian delivered
69,000 km's
Bright red duco
Black leather interior
all the usual options associated with Honda's most expensive vehicle.
Cd and incar stacker, cruise control, 2 trip computers, fastest electric roof available on any car on the market.
176kw of power, rear wheel drive, lsd etc
This is the fastest production NA 4 cylinder car on the planet, and is amazing to drive. Car is in perfect condition.
2. Honda S2000 $43,500
2001 model
Jap Spec
10,000 kms
Metalic Silverstone
same optins as listed on above s2k.
This jap spec model has 184kw of power, slightly more then the australian delivered spec car.
This car also has an in-dash tv from factory, it comes with the japanese navigation system, but an aftermarket dvd player has recently been fitted to the car.
This s2k is also in fantastic condition and will suit a new car buyer.
3. Nissan Skyline R33 GTST $20,500
1994/95 model
80,000 kms
Grand prix white
Apexi N1 exhaust
18" forged wheels
Original Nismo 400r sideskirts, 400r rear bar and pods, nismo 'tall boy' spoiler, nismo stealth lip, and aftermarket GTR front bar.
BOV
HKS intake
white dash
CD/radio
strut brace
Very good and clean condition, never boosted, engine and turbo untouched. Perfect for next step of modification.
You can contact me on 0431-116-919 or PM
Thank You
https://www.sau.com.au/forums/topic/46425-2-honda-s2000s-and-1-r33-gtst/
Hello guys, I have been offered trade for R32 GTR, R33 GTR, audi, and bmw etc... I am not willing to trade any of the cars as I need to sell the cars for money... as in cash, cheque, gold bars, crude oil etc I am not interested in swapping, trading, etc. Sorry. hehe
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
