Hey all,
I have an occasional situation when I drive very hard in my S2 NEO Manual 4WD Stag - boost pressure loading up, and all of a sudden dropping very low, then bouncing back up again. Drop and surge, it seems. Not consistent and doesn't happen that often, but has happened more than a handful of times. Seems to happen more when my boost controller is set to high boost.
Things I'm wondering about;
- fuel delivery issue
- spark issue (coilpacks?)
- boost limiter?
Some extra context; car has cat-back, BOV, EBC, boost gauge - none of which I installed. It's possible the EBC is set too high at 'high' mode. On one full boost run that didn't result in the boost dropping, I saw (to my shock), the aftermarket boost gauge go to 1 bar. Normally I see it going to about .7 bar. I don't have an OBDII reader or else I would check codes.
I'm thinking it's just set to boost too high, but interested if anyone has experience with something similar (I've read in another thread and it sounded like the factor boost limiter kicking in).
If it is boost limiting that's to blame, my guess is that I should be thinking about bigger turbo, fmic, injectors, fuel pump, nistune/safc. Would that be the right way of looking at it? Alternatively I'm wondering if I could add a SAFC as the next thing, to control how rich it's running due to the EBC.
Thanks
Edited by ls_stag
https://www.sau.com.au/forums/topic/465883-boost-pressure-dropping-and-surging/
can you show the settings details for EBC? "high" settings is usless for us unless you provide each settings value.
try set "GAIN" to 0. high GAIN will cause boost spike.
Edited by YangLIU
  • Like 1
Good point, tonight I will dig up a manual for the EBC online, and see what I can find. Low boost seems to be yielding a consistent .7 bar max boost. Car pushes far harder when set to high, but I will check settings tonight. EBC also has a 'manual' control with a little turnable knob. Will check that out as well (and obviously avoid overboosting). I'd like to be seeing 12 psi / 0.82 bar on the high setting. From what I've read, that sounds reasonable, running premium fuel, BOV and the cat-back.
15 hours ago, BoostdR said:
sounds like boost or flow cut. A nistune will fix it.
I figured that'd help a lot. Going to be tricky to find a tuner here in Vancouver, BC I think, and I'll have to wait a little while for the budget. In the meantime, I just want to have a consistent setup if possible!
if there is no problem when using "LOW" profile. then set same value for "HIGH" profile. normally just SET ang GAIN could control the boost. then turn up SET value bit by bit until you see your target high boost. then turn up GAIN value bit by bit until you see boost spike, then turn down  GAIN value a bit. done.
normally i'd suggest use Blitz SBC/Greddy Profec EBC which could show real time boost graph that easy to setup by ourselves on the road.
Edited by YangLIU
Thanks for the tips! Having done some digging last night, I have figured out that I have an -ancient- HKS EVC 1/2. So it is very, very simple. After playing around and doing some runs in 3rd last night (driving), I have figured out that with the EVC turned off, I have constant 6.5psi, with it turned on to Low, I have constant 10psi, and I used the 'Manual' dial to achieve a constant 12 psi. I'm now very interested in getting my hands on a GFB G-Force II (http://www.gfb.com.au/products/boost-controllers/electronic-boost-controllers/g-force-ii-electronic-boost-controller-by-gfb), having seen a couple videos about tuning it. Looks like a great unit at a reasonable price.
Also, planning to get a Super-AFC II off ebay and do some fuel adjustments as I assume it's running rich, especially in the top end. Driving it with 3/4 throttle on high boost actually feels far more responsive, and changing through gears without redlining results in faster acceleration - feels like its running leaner and faster. Wondering if anyone has had success doing their own SAFC mapping without using a dyno? Saw a guy using a Zeitronix kit online, but that's another $300USD for the data logger/laptop software. It looked The Biz, but I'm wondering if it's possible to get a good map without such a heavy AFR logging system.
Cheers!
Cheers!
good to dig EVC problem.  i would still suggest the EVC which could show real boost graph that easy to tune the car by yourself
for safc, i would say you can tune by yourself on the road but at least you need AFR gauge with wideband O2 fitted
  • 2 months later...
@YangLIUdidn't get around to saying thankyou for your post.
Going to rip out the old EVC and replace with electronic unit. Considering doing a Nistune upgrade on my ECU in the future, so going to leave the SAFC/wideband AFR gauge for now. Seems like I could get the Nistune + tune + wideband o2 sensor for only a few hundred more than the SAFC + AFR gauge setup.
If you are going to spend megabucks on an electronic boost controller and a Nistune consider instead getting a Link Atom ECU
http://www.ebay.com/itm/Link-G4-Atom-ECU-Top-Quality-Entry-ECU-at-Budget-Price-4-8-12-cylinders-/122046134336?hash=item1c6a843840:g:bzUAAOSwqfNXiJHH&vxp=mtr
which together with a Mac valve will give you electronic boost control and a great ECU and you can get it tuned in Surrey (they are dealers - you might find a tuner closer):
Independent Speed Shop 604-533-1548 Surrey Canada British Columbia
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
