Hi all im thinking about passing on my apexi el 2 gauges, i have a boost, oil temp and water temp gauges with all sensors and control unit. The gauges are blacl bezel with white face in 60mm.. never been used still brand new in boxes. And also has the daisy chain wire too.. i payed around $900 plus postage. I will let the whole kit go for $800 plus can post at buyers expense. Genuine not fake... located in geelong Victoria. Cheers fe97eadb5ae58e5e920bf63ec1a30895.jpg
https://www.sau.com.au/forums/topic/466766-apexi-el-2-gauges-control-unit/
If someone wants them this week i will let them go for $750 posted anywhere in Australia.. but only if sold this week... thank you.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
