Can anyone give me information, pro and con's about these three different types of Fuel Pressure Regualtors?
Do they all do the same job as well as each other?
The nismo item looks like the stock reg, but with a screw on top, where as the malpassi and sard are more solid, robust units. Would this affect their performance?
I''m just a little confused with these products.
Cheers
Dave :headspin:
https://www.sau.com.au/forums/topic/46722-malpassi-vs-sard-vs-nismo/
I queried between sard and malpassi at gavin woods and his response to malpassi involved some fairly heavy language which I possibly shouldnt repeat in polite company. It wasnt a positive response, put it that way.
I dont actually remember what brand he did reccomended over all, but I know sard was a name that cropped up as a "good" one.
ok thats a technical response slapper... but WHY??
is it because its not a jap brand... is it because it costs 1/3 the price of the Sard?
Gavins reasoning (minus most of the more colourful words) was that the malpassi couldnt maintain its set pressure between full boost and idle, especially after a hard run then quick back off. You would see the malpassi holding full boost fuel reg pressure even at idle, or vice versa (ouch!)
Also the build quality was "shit" and "typical of italian crap" and "I wouldnt even throw one on at my worst enemy". ... Thats not entirely verbatim :)
lol nice.
well thats the sort of info i want. I do know that the malpassi's work as i've used one on a previous car with no drama's, but i just want to justify the $300 odd for a sard or nismo item.
Cheers krawler
thats my other query.
The nismo's look like the stock fuel reg, but with a screw on top (the one i owned did anyway)
How do they go at controlling boost? are they rising rate etc? Their small design makes me abit wary of them...
Look at the nismo one that bolts on. It looks like stock.
All it does is restrict fuel on the return.. how can a different brand really have that much difference?
Skyline-Dave. How can it control boost..? And unless you running enough fuel for 4000HP I can see the small size hurting?
And I would say the Nismo one is all you need.. they have been proven to work. Rising Rate is not always a good thing.. you should use tuning to get the fuel right.
Cheers
Dave  :headspin:
Dave;
I've heard only good things about SARD, and Nismo aren't known for making junk. That said, make sure you need one before you spend the $.
yeah i've got a bigger fuel pump, and injectors will be >660cc i have decided.
I want to make sure i am going to be completed protected on the fuel side of things. Hence asking all the questions. Alot of money is going into My RB30DET and the GT35R will be wound up in boost pressure.. so i want make sure i'll have adequete fueling.
^rising pressure reg. are usually 'band aid' fixes people use to flow a little more then what there injectors can handle with normal fuel pressure... and as most band aid fixed its best to do the job proper and just get bigger injectors
ive also heard similar bad things about the malpassi, and have been recommended the sard over it, reason given was that the malpassi cant hold a steady fuel rail pressure, and well if that is the case, then its a pretty pathetic product really isnt it
i recommend you not even go with the fuel regulator, run stock fuel pressure, and run bigger injectors if your running out of fuel, IMO, if your increasing fuel rail pressure to make up for lack of fuel, then your injectors are too close to 100% duty cycle anyways, and again in that case its a safer option to go with bigger injectors, if you want to be safe, which you say you do
pushing the injectors too hard will increase the chance of something going wrong, your spray patterns are also affected when you push the pressure too high
You can also push some more current through the pump to raise the static pressure....
I think.,
mmm i doubt it will, unless you have a shitty regulator, the pressure is simply a result of the restriction from the pressure regulator and it should accomodate for any extra flow and keep its pressure consistent, although its a common DIY trick to upgrade the wiring to your fuel pump, so you get less voltage drop + more current to the pump, which increases its FLOW, not pressure
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
