Gday guys
I was wonderig if anyone out there had]s experienced the problems i am having with my misfiring engine. Currently the engine accelerates up to 3000-3500 ok. The problems then start. If I try to accelerate using full throttle the engie misfires and pops out the exhaust. It feels really flat and hesitant. Once the engine finally reaches approx 5500-5800 it takes off like a rocket all the way to the limiter. I am having thoughts on the coils and perhaps exhaust cam timing.
Mods are:
Hi flow turbo, 3" inch mandrel turbo back, plug gap 0.7, boost set at minimal 12psi,
checked A/F ratios , are fine,
If anyone has any thoughts could you please assist before i need to start spending big bucks, Knowledge in Tassie is minimal as the low volume of these vehicles.
Cheers
Nick
https://www.sau.com.au/forums/topic/46767-misfiring-rb25det/
Hi Nick,
Am interested to know what kind of boost you are running. Is the amount of boost dropping off at high rpm? I ask this because it is harder for a spark to jump the same gap in a higher density atmosphere. Reducing the gap or cutting back boost may prevent the car misfiring, but will put a dent in your performance as well.
I'd be inclined to try out a set of Bosch Super 4 spark plugs if you can get a set to suit, as they do provide superior ignition. Otherwise you may need to get a set of coils or an ignition module with a stronger output depending on which is holding it back.
https://www.sau.com.au/forums/topic/46767-misfiring-rb25det/#findComment-950796
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
