2000 Nissan Stagea Autech 260RS WGNC34 Manual 4WD
Rare late 2000 Model Nissan Stagea Autech 260RS 4WD – 2.6L Twin Turbo Godzilla - GTR Wagon!
Series 2 with all the bells and whistles including higher spec NEO version of the RB26!
*** MECHANICALLY UNTOUCHED, only minor Cosemtic mods. Best looking WGNC34 around! ***
Car is mechanically perfect, exterior is in showroom condition and the interior is practically brand new! (only flaw is small crack front bumper $300 to repair) The car genuinely drives as if straight out the showroom, handles unbelievably well with coilovers & strut brace and I'm confident the first to Test Drive will buy! A unique and rare collectable, I guarantee this will be the most untouched and cleanest example you will find.
* Low kms 116,xxx - Major service completed including timing belt changed at 102,000kms
* Standard Brembo Brakes and ATEZZA Active 4WD system
* Standard 260RS Stock Coilover Suspension
* Standard Front Strut Brace
* Standard Series 2 260 RS Full Bodykit (including updated front grill and front bumper, rear roof wing, side skirts, rear bumper, clear side indicators, roof racks)
* FMIC
* Upgraded R33 GTR Seats
* AVS 17 inch Matte Black Lightweight Racing Rims
* Tinted Windows * Xenon Headlights
* Fog Lights
* Non-smoker vehicle with nil accident history
Car is 100% stock standard with no modifications from factory (running factory boost). Vehicle is in A1 condition, mechanical tests welcome. Car is being sold with RWC/Safety Certificate + 12 Mths Registration! $24,900 Neg. for quick sale
*** Call or Text, as I don’t check emails ***
Thanks
Nimal
VIC - Mount Waverley 3149
0404 596 178
Edited by eFjAY
  • 3 weeks later...
  • 1 month later...
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
