Rays VOLK TE37 18x9.5" +12 with Yokohama Advan A048 Semis
Genuine Bronze TE37s in the GT-R size and offset. 2001 built, in great condition.
Minimal marking around the rim,  OG bronze - never painted or refinished. Just a few small marks where leg nuts have been dropped.
The Rays and VOLK stickers are intact and in great condition.
 They come wrapped in Yokohama Advan A048 semi slicks with around 40-50% tread.
$3200
Located Melbourne North Eastern Suburbs, pick up preferred.
These are THE rim for your GT-R.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
