Hi Blade,
Give GTTR34 a PM... I'm sure he has a set going real cheap with 85-90% tread and he's in Melbourne.
EDIT: stuffed the link!! All fixed now.
yeah mate
i pm him like 2 times and sent him 2 emails and still no reply...
https://www.sau.com.au/forums/topic/47441-tyres/#findComment-959317
hmmm not that desperate if their "cheap" :rofl:
Desperate to buy a good set lol :(
tahnks anyway bro
i cant appkly any boost in the wet without fishing...its really pissin me off
I might have to bite the bullet and spend $$$ on brand newys
https://www.sau.com.au/forums/topic/47441-tyres/#findComment-959611
Might be an idea......... especially since you are asking for AT LEAST 90% tread.....may as well call them new.......Perhaps try a tyre shop I hear they sell this kind of stuff
Spare me the sarcasm
obvously urve failed to see in the for sale section over the couple of years numerous threads of people offloading second hand tyres with great tread, aswell as 2nd hand tyre recyclers and wreckers offloading good cond rubber for a good price cheaper then retail
Melbourne trading post has classifields for tyres around 80 to 90% tread but none in the size i need
I didnt say AT LEAST 90% i said around...
Before u type some bs in someone elses thread how about u save urself the time and do some research so u dont have to get owned and make a fool of urself and also waste my time and most possible the moderators time for clearing up ur shit in my thread so delete ur brainless dickless post and never submit a reply to my thread ever again
Since your such a smart guy who states the obvious... heres some older threads to wrap your bite size brain around...and this was in the 1st page of 500...
http://www.skylinesaustralia.com/fo...highlight=tyres
https://www.sau.com.au/forums/topic/47441-tyres/#findComment-960170
It "could" be my bite size brain.........but none of those links work.
The point i was trying to make was that you are.... "getting pissed off with fishing up the road", That would lead any normal person to the assumption there is some form of urgency. Therefore a tyre shop would be able to help you.
https://www.sau.com.au/forums/topic/47441-tyres/#findComment-960574
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
